help with a zanussi zwx1605w
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries help with a zanussi zwx1605w
  • #58698
    curlycotton
    Hi folks
    have a zwx1605w lost its module config anyone happen to know the module config procedure or have a service manual my tds disc a little old now and don’t cover this one or in case i’m barking up the wrong tree error beeps 3 times starts to fill drains and goes to end beeps three times only done this after power cut have tried reset, mega’d heater element ok, checked pressure switch any help much appriciated
    cheers Curly ❓
    #335349
    Re: help with a zanussi zwx1605w
    That has an EWM1000 series module that is pre-configured. Error codes as per Known Error Codes thread after going through ‘diagnostic cycle’.:wink:
    #335350
    Seamy
    May have detected too much detergent, go into diagnostics, fill with water & drain to see if it resets itself, check its draining ok as most will lock up on start-up if theres water in it, it runs pump for a few secs & if water level doesn’t go down it will show fault, also check drain hose has air gap & it doesn’y syphon
    configuration fault/errror code would be E90 something
    3 beeps E30s are water level/pressure sw’ faults
    #335351
    Loads of files on mediator at Connect site. If you’ve got an account, look there. If not, post up PNC no.
    Mike.
    #335352
    curlycotton
    Yeh Cheers for that guy’s
    will check out 🙂
