help with an ariston a1636
Home Forums Public Support Forums Help And Support Washing Machine Help Forum help with an ariston a1636
  • #41165
    jemima23
    it has a fault the door looked ight andthe 4th light down are flashing the 4th being the”rapid”light
    any advice?
    #269004
    jemima23
    sorry about the bad typing that was supposed to read ddor locked light and the 4th light down bwing the “rapid” light thankyou x
    #269005
    jemima23 wrote:sorry about the bad typing that was supposed to read ddor locked light and the 4th light down bwing the “rapid” light thankyou x
    I should take those boxing gloves off if I was you Jemima. 😆
    Light 4 flashing suggests a motor triac error. Can be caused by loose or broken wiring near the motor plug but is more often than not a faulty main PCB. A quick look around the forums will give you an insight into the relative merits of Indesit made appliances. 😥
    Don’t worry about the other posts in the spin drier thread. 😉
