hello all, I need help with awod4505 fault code all i can get is it to drain. if I put it on any wash it runs the drain pump for 20-30 secs then the wash and rinse light come on with the service light.. does anyone know what this can be?
Fault -The failure modes are checked before the cycle starts.
Potential causes
:- Resistance of heater
:- Resistance of heater connectors to ground
:- Wiring connectors to heater and CUC
:- Check the CUC
hopes this helps if not pm me your email and I will forward text legend (fault codes). 😀
