help with cda dishwasher please
Home Forums Public Support Forums Help And Support Dishwasher Help Forum help with cda dishwasher please
  • #71843
    pughy2000
    I need help with my intergrated dishwasher
    The model is a cda cw 494
    We ran out of dishwasher tablets and the missus put some fairy liquid in the tray instead
    I spent an hour cleaning out all the bubbles and water
    It still worked for about 20 mins but then something tripped the electric not sure if it was the dishwasher or something else that caused it.
    After putting electric back on all the lights on the dishwasher still work but when i shut the door nothing happens
    Is there a code to reset it of some kind or would all that access water and bubbles maybe caused another problem?
    Any advice would be appreciated
    thanks
    #382538
    pughy2000
    Re: help with cda dishwasher please
    can i just add there are no flashing lights or beeping noises at all when i open or shut the door
    thanks
    #382539
    There are a few versions but, if it’s the original CW494 it should use these fault codes as it’s a Whirlpool manufactured dishwasher.
    http://www.ukwhitegoods.co.uk/help/faul … codes.html
    There sin’t a reset as such and, if there’s a problem you should get one of those codes as a flashing light on the control panel.
    Other than that it’s a case of testing till you find what’s gone wrong with it but, 20 minutes in, it should have powered up most things which is a bit confusing.
    pughy2000
    thanks for the reply
    as soon as i shut the door it starts straight away normally.
    I am getting no error codes at all just nothing happens when i shut the door
    I thought it might think it was stuck in a cycle
    I read to put on rinse cycle,power off, hold the start button and power on until it flashes , then press the start button once and shut the door to start a test cycle.It does not work though.
    I just took the front panel off and the circuit board didnt look damaged. I could not see the pump, i think in must be in the very bottom panel but i have no small allen keys to check
    #382541
    Okay, first things first… there are often no quick answers, you need to work out what the dishwasher is doing or, trying to do when it stops.
    It’s fault finding 101 if you like and, it’s all logical. 😉
    Start by having a read of this…
    http://www.ukwhitegoods.co.uk/help/fix- … shers.html
    The trick is, figuring out what’s engaged or being energised when it pops.
    You can eliminate the pump, that runs as soon as you start a program.
    Then the fill valve.
    Then the motor.
    Then the heater.
    It’s a simple process of elimination which is time consuming I’m afraid.
