HELP WITH ERROR CODES Indesit WIL123S (flashing lights)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HELP WITH ERROR CODES Indesit WIL123S (flashing lights)
  • #17155
    chrisfunk2000
    I have searched and searched for a list of error codes for this machine
    and can only find lists with details of readable codes, can anybody help?
    The usual red light flashes quickly as well as green lights 2 and 4
    (from left).
    It seems to be something to do with drainage as it always gets stuck near the end of a program before it should spin. But, the machine can drain, and does so earlier in the cycle, before rinsing for example.
    If the machine is turned off/on I can select drain manualy and it works, then selct spin manualy, and that works.
    By doing this I can get a complete wash but it will not run a full cyle by itself.
    Please help!
    #173160
    Re: HELP WITH ERROR CODES Indesit WIL123S (flashing lights)
    It is the pump or the hose to and from the pump that are restricted in some way as the ‘error code’ does relate to that 😉
