My Fisher Paykel GW709AU has stopped filling up. When I try & use it, it starts to agitate but doesn’t fill with water. It is displaying a Code 50 which I have read is the Hot Water Inlet Value, but when my husband tested it with the multimeter both the hot & cold valves don’t have the 64ohms that websites are saying they should have. From the research I have been doing, websites have said that it could be either the hot or both the valves, the pump or even the motor contol board. Is there a way that I can do a more conclusive test on it before I go out & start buying parts to repair it. I don’t want to be spending more than I need to.
Kind regards
Nell
Re: Help with fixing my Fisher Paykel GW709AU (Code 50)
After getting some advice, my husband check the valves again & got 63.9ohms on the cold & 33ohms on the hot. I also did the valve diagnostic test this morning. The led light lit up for both valves but I didn’t get any water to come out of either. Do you think that that is more indicating that it is a wiring problem?
Kind regards
Nell
