Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › help with indesit WD12x fault & error code
- This topic has 5 replies, 2 voices, and was last updated 17 years, 10 months ago by
zen.
June 6, 2008 at 4:03 pm #37224
zen
Participanti have an indesit washer dryer and the machine continuously fills and pumps out water while the program dial constantly turns. as this is happening the door open indicator light flashes 3 times then pauses for a bit and flashes 3 times then pauses then flashes and so on.
can anyone help me with the error code if that is what the flashing light is or does anyone know the fault i havethanks in advance
June 6, 2008 at 6:29 pm #253930helo_75
Participantf3 is usually down to the ntc fault.. that being said, commonly, the pcb doesnt sense it
the ntc is the sensor on the heater, dependant on variant, the ntc will be in the heater, or on the back of the tub, just above the heater
its wise to check for broken wires first (with plug out, of course)… the ntc is inexpensive ( last price i saw was under a tenner), but experience would sugest the pcb is ast fault, and with that, you’d need an eprom
it will be eiTHer This http://shop.ukwhitegoods.co.uk/Washing+ … ensor.html
or
this http://shop.ukwhitegoods.co.uk/Washing+ … 2FNTC.html
a quick look on the back of the drum will confirm which one it is
up to you if you want to try an ntc first, good luck
hope this helps
June 9, 2008 at 8:06 pm #253931zen
ParticipantRe: help with indesit WD12x fault & error code
thanks for the help so far. gonna order the sensor 2nite to give that a try.
whats an eprom though??
June 9, 2008 at 9:02 pm #253932helo_75
Participantits a programmed chip that plugs into the pcb, to tell it what it is
a complete necessity
June 16, 2008 at 4:56 pm #253933zen
well looks like the sensor solved the problem but i am getting a little water leaking out from around the new sensor. is there any special sealant which can be used to cure this??
cheers
ZenJune 16, 2008 at 6:29 pm #253934helo_75
Participanti take it its on the back of the drum, not in the heater?
is what i use, and im sure others do too
