help with lux dw problem pdf if poss
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries help with lux dw problem pdf if poss
  • #52775
    simon26r
    Hi. its been a long time since i have posted on here and i’ve lost my lux login info so any help would be grate
    esf63020x
    911 519 026 02
    d/w will fill heat drain and then stop.
    I have the cancel light fashing fast and the 3rd light down with 2 flashes every 5 secs it has the symbol os a arrow pointing left to a line…
    if anyone has a pdf they can send me or give me clue would be great..
    oh yes its also english bugarian machine…
    thanks all
    simon
    #313091
    TELL
    Re: help with lux dw problem pdf if poss
    email address. might have something to help.
    TELL..
    #313092
    bigchrisoioi
    i20 fault…..pump not pumping correctly…make sure the pump entry point in the sump is not blocked with pits of rubbish…take filter out, its about ‘5 o clock ‘ down the sump, there is a small grate which is the entry for the pump…i normally find bits of glass, plastic, food blocking it….thats normally a quick and easy repair!
