hello i have a diplomat with the seral number 330325007704 dishwasher., it was working fine then it started making a bleeping noise untill i opened it, the button that has a green light on it with a dimond back ground started flashing i counted the flashes thay remain the same no faster or slower. i turned it off cleaned the filter cleand the drain and cleaned the waist pipe under the sink. then put water in to the bottom of the dishwasher to see if i drained it did that ok then as soon as it drained it did the beep beep and wont go onto a program. please help thanks. michelle 🙂
hello again i just tryed to put the dishwasher on after turning off the button thats flashing green that looks like this and the dishwasher makes a noise as if its starting up then the beepin noise starts i open it up and the button i turned off is back flashing green and beeping and its still dry inside.
