Help with replacing Siemens fan oven element
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Help with replacing Siemens fan oven element
  • #49681
    MTBing
    The model no is HB 903 55 GB / 05
    I have the spare part and it should be easy to do. The problem is that the top screw that holds the element in place is partially behing the fan. This means (I think) that I need to remove the fan first.
    Again, should be easy. I have removed the (clockwise turning) nut from the centre of the fan and was expecting the fan to simply pull out – but it doesn’t!!! Does anyone know why this is the case and what I need to do to get it out?
    Have spent far too long on this already – happy if I eventually get it fixed but not if I have to get an engineer out!!!!!
    Many thanks
    #300677
    Re: Help with replacing Siemens fan oven element
    Give the fan shaft a good soaking with WD 40, wait a while and it will usually allow you to pull it off.
    #300678
    amigos
    The fan element on the bottom oven of our Siemens HB903 double oven has blown four or five times since we bought the oven in 2003, and it has cost me over £100 on average each time to get it repaired. The element blew again this week, and this time the repair man couldn’t get one of the screws off. He advised against using WD-40 as he said he used WD-40 once and it took ages to get rid of the smell. However, he moved the oven out into the room and he was able to fix the element from the back. It cost me £167 this time – I definitely won’t be buying Siemens ovens in future!
    #300679
    nomadPaul
    The element design in your double undercounter oven has been totally changed now. The half-moon design has been replaced with a total circular element meaning the failure rate has dropped dramatically.
    Remember that Siemens single ovens & full size double ovens use a full size circular element. Only the double undercounter ovens used the half moons……which I agree , do suffer failure , earlier than expected .
    #300680
    russell knights
    i have had this problem many times b4
    heat the fan up near shaft with small blow tourch, which will allow u to pull off fan without causing damage to fan and fan motor shaft,works for me
    #300681
    BigCol78
    Put the nut back onto the shaft a little and give it a knock with a nilon or rubber hammer that should loosen it give it a move from side to side and it should come off.
    Hope you manage it BigCol.
