Help with Samsung Code
  • #29301
    a1al
    Just been out to a SAMSUNG RS21DCNS side by side F/F.
    Before I removed ice blocking evaporator fan in frigde side it showed a fault code ( bottom segment of most right hand side 8 on display panel was lit up) Can anyone tell me what this code is and is removing the ice a fix. The fault code was gone when I tested at end of job.
    Thanks for looking
    a1al
    #222666
    whizzkid
    Re: Help with Samsung Code
    fault code is refrigerator defrost sensor failure, sensor connection, wire cut, short circ or sensed temp is above 65c or below -50c.
    =replace defrost sensor to cure.
    #222667
    Hi A1al
    The correct fault for the error you have given is that the fridge fan has a fault.could be open circuit or disconnected or jammed.
    Check that the defrost system is working correctly and that the evaperator is clear or that the evaperator panel hasnt failed.
    When the appliance is switched off and then on again this clears all the fault codes,It will then take approx 12 hours before the fault code can return if the fault is on the defrost cycle.
    Wizzkid have a look again at the fault chart.Or better still azttend Sibson at the end of september as your in the west mids wont be too far for you even for the 1 day.
    Bryan
    #222668
    whizzkid
    yes brian, i got that, but understood fault code to be bottom right hand segment on the right digit?
    sorry,
    i stand corrected if wrong
    cheers neil.
    #222669
    Hi Neil
    you can still cme over to sibson anyway.
    Bryan
    #222670
    a1al
    Hi Guys
    Thanks for the replies are you both saying that it is the defrost sensor and if so any idea what the part No is and where is the best place to buy it from
    a1al ( N.Ireland)
    #222671
    Hi Al,
    The parts you need should be in this section of the shop
    HTH
    expertcat
    Bottom rhs is defrost sensor out of tolerence.
    #222673
    a1al
    Hi Guys
    Just to be clear the fault code is the very bottom horizontal segment on the most right hand display digit.
    Sorry if I was not to clear the first time,
    any chance someone could post these fault codes on the fault codes page or email or post me a copy I would be willing to cover any costs involved
    regards
    a1al
    #222674
    The fault is per my previous post a1al.
    Bryan
    #222675
    a1al
    Thanks again guys for all your help
    Fan blocked with ice now working, but will post again if different code appears
    regards
    a1al
