Help with SMEG extractor !
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Help with SMEG extractor !
Viewing 15 posts - 1 through 15 (of 17 total)
  • #103324
    DizOra
    Can someone kindly help?
    We have a Smeg Cooker Chimney Extractor that was bought in 2018. Model: KD610XE
    It’s now developed an issue where the motor doesn’t seem to work.
    – On Setting 1 or lowest suction: When started on this, can hear a whirring sound from motor but doesn’t work.
    – Setting 2: When moved upto 2, the noise gets louder but again motor doesnt seem to be working.
    – Setting 3: It starts to work but doesn’t sound normal & stops shortly afterwards.
    We tend to clean the steel filters but don’t touch the motor, due to which there is lots of grease around the motor.
    We had an engineer from a local firm around to look. This was their diagnosis:
    “Motor brushes were needed to complete a repair. Unfortunately, upon checking the exploded view and part listing for your specific appliance, the motor brushes are not listed as a separate part to the motor, so we have no option but to quote for the motor assembly.”
    Their quote came to more than the original purchase price of the extractor !
    I called up official SMEG helpline & the kind lady said that its most likely a control panel fault & the motor won’t need replacing?Agree she hasn’t had a look at it but don’t want to pay for another engineer visit !
    I’m a bit confused.
    Is it the control panel or the motor ?
    In which case, control panel will be cheaper??
    Can someone kindly help ??[IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”src”:”https://www.ukwhitegoods.co.uk/forums/core/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==”}[/IMG2]​
    #492668
    DizOra
    Just to update, even the 3rd setting has given up now !
    #492669
    kaibart
    I find that odd that the local guy said it needed brushes as most cooker hoods are brushless motors, for your model the part is a complete motor if you contact smeg direct they are very helpful and will supply you with part number and price
    #492670
    it does sound like a motor issue and it’s a brushless motor so, complete unit in any event and those are not cheap.
    can see why your confused when the only advice you get is from a complete idiot
    first off try and get at the motor and see if it spins freely
    if no you may be able to srip it and add some light oil. not a permanent fix but may give you 12 months or so
    if it will spin it may have a capacitor and these are often cheapish so worth a try
    They don’t show a cap in that one Dave, it’s an older type with the small switches in the switchback.
    kwatt wrote:They don’t show a cap in that one Dave, it’s an older type with the small switches in the switchback.
    probably stiff motor then
    or bad windings
    DizOra
    Thank you so much for all your help & feedback. Much appreciated. Feel like I should ask for my money back from the local firm as they haven’t even diagnosed the issue correctly (brush motor). I think it might be cheaper to buy another one considering the labour & motor replacement costs !
    #492675
    yes its a very expensive motor for some reason. I have got a motor that seems to look identcal but the motor unit inside is different so i can only assume the have fitted a better quality or higher power motor
    if it was me i would first take it down and strip it so see if the motor is tight. after all it may need a little oil and it might continue to work for a while
    you have nothing to lose as its broken now
    DizOra
    Tried giving it a go as per suggestions here. Is this burnt out ?? Does that mean motor has to be replaced ??
    #492677
    No, that’s not burning just grease etc that’s got on it most likely causing discolouration.
    if it burns cout it will stink the place out
    does it turn freely ?
    DizOra
    Yes seems to turn freely, dont think motor is the issue?
    We couldnt take out the switch panel.
    Also, is this a brush or brushless motor from the picture above ?? We don’t know the difference.
    #492680
    no extractor would use a brush motor in this situation
    does sound like a shorted coil issue in which case its new motor time
    and its a silly price to a lot of the standard hood motors
    DizOra
    Going down the route of buying another extractor ! That seems cheaper
