Home › Forums › Public Support Forums › Help And Support › Other Appliances › Help with Steam generator iron
- This topic has 7 replies, 2 voices, and was last updated 12 years, 10 months ago by
b21playa.
June 10, 2013 at 4:58 pm #75796
b21playa
ParticipantHi all
All of a sudden our iron has stopped producing steam. The soleplate still heats up.
Model – Kenwood G-1030ST-E
I think it maybe the pump as I cannot hear it, and the ight on the control panel does not light up.
Is there a way of testing this, and are spares available?
thanks in advance
June 10, 2013 at 9:48 pm #396173electrofix
ModeratorRe: Help with Steam generator iron
from the website i looked at the only thing available is the anticalc filter
as far as the steam is concerned could be pump, element , thermostats, pcb or switches but since it does not look as though they are available its scrap
find kenwood and ring them to check
June 11, 2013 at 5:30 am #396174b21playa
ParticipantRe: Help with Steam generator iron
electrofix wrote:from the website i looked at the only thing available is the anticalc filter
Thanks for reply
Managed to get it kind of working, issue ended up being broken plastic cover switch.
Issue I now have is that steam is coming out of the main unit as well, which is from the pipe from the top of the boiler
June 11, 2013 at 8:22 am #396175b21playa
ParticipantJune 11, 2013 at 11:22 am #396176electrofix
from what i can see that looks like a safety valve
June 11, 2013 at 3:06 pm #396177b21playa
electrofix wrote:from what i can see that looks like a safety valve
I did think it was a pipe to release excess steam to stop the boiler exploding. The pipe just connects to a plastic prong on the base.
Im wondering whether its worth removing the boiler and giving it a clean or any limescale?
June 12, 2013 at 9:17 am #396178electrofix
its worth a try
June 12, 2013 at 9:37 am #396179b21playa
electrofix wrote:its worth a try
I removed the top part which was full of limescale build-up. Cleaned out just the top part and its still coming out of the pipe.
Last try tonight will be to remove the entire boiler and check all pipework. If that fails its time for a new one
