Help with WDL520P inlet valve
Home Forums Public Support Forums Spare Parts Help Help with WDL520P inlet valve
  • #77275
    longplay
    I’ve traced a leak on my WDL520P back to the inlet valve, but I’m struggling to find one that matches and I’m hoping someone can help.
    There are a couple of sub-models of the 520P a C and K. I think I have the K one (56871).
    My valve looks like a triple unit (part no. C00110331) but mine has a sort of extension stuck on the end that allows it to reach the back panel, which none of the images I can find have.
    Searching a few spares sites, some suggest that particular unit only fits the C model, and the only other option is C00269609, which comes complete with dispensing tray, which I don’t need. Some of the pictures do seem to suggest the valve has the extension though.
    Can anyone help clarify which part I need?
    #401609
    Re: Help with WDL520P inlet valve
    Only comes with the dispenser top, later dispenser top has been extended in length to allow for the lack of the extension on the later valve.
    Part number you require is C00118578.
    #401610
    Andy jones
    Make sure you order the plastic valve holder as well
    #401611
    Andy jones wrote:Make sure you order the plastic valve holder as well
    That part is included with the above as part of a kit. 😉
    #401612
    Andy jones
    About time they put in the kit. They never used to
    #401613
    longplay
    Thank you, just the job.
    Only problem is the C00118578 seems to be discontinued, with some sites (inc UKW) suggesting the C00269609 is the replacement for it.
    Anyone confirm that?
    Cheers
    #401614
    Screen shot from the latest version of Partfinder.
    Although this is the Indesit Company, any way to screw another £20 out of you. :rolls:
    So if you order the part number I gave you are likely to receive the complete assembly.
    If you order the C00269069 there is a chance you may not get the bracket.
    #401615
    longplay
    And the rest! I only need the inlet valve, about £12 for the C model, instead of £50 for the whole lot and a dispenser tray I don’t need!
    Thanks for info.
