help with whirlpool DWF 417
Home Forums Public Support Forums Help And Support Dishwasher Help Forum help with whirlpool DWF 417
  • #31563
    emmajayne18
    hope someone can help.
    My dishwasher getts towards the end of the cycle and then starts beeping (twice) , it makes a short churning sound and then beeps and churns again. It has been doin this for about half an hour now! When I open it up there is water in the bottom but nothing is cloged up.
    I have read the instrctions and it says nothing about this problem. I am not too sure what to do now. It does this on both the intensive and standard cycle and the only way i can get it to drain is by puttin it on the rinse cycle!
    Thanks :rolls:
    #231674
    Re: help with whirlpool DWF 417
    Check whether or not the start lamp is flashing in a pattern – ie 1-2-3-4-pause-repeat.
    emmajayne18
    Sorry to be stupid but which lamp is that…is that the light that you use to select the programmes?
    Thanks 🙂
    #231676
    emmajayne18
    Just checked and the lights that are flashing green are the pans and plates ones…They say ‘end’ above so I guess this is to signal the end of th cycle?!
    #231677
    emmajayne18
    Anyone?
    #231678
    This is an odd one……. The machine is badged Ikea, sold by Whirlpool and made by either SMEG or Bosch.. :conf:
    We’d need the 12nc code to work out which one you’ve got – that’s the number starting with 8.
