HELP!bosch SRS55C02GB too tall. can i replace weight on top?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum HELP!bosch SRS55C02GB too tall. can i replace weight on top?
  • #38958
    kimba
    my new bosch dishwasher won’t fit under the counter. the floor is uneven and even with the top removed the back is too tall. the weight takes up a couple of inches and it fits without it. can i get some handy person to fit it with a similarly heavy weight that is flat (there is room for that) will that screw it up entirely or just a little? after all it doesn’t need balance as much as a washing machine does. thank you, k
    #260486
    Re: HELP!bosch SRS55C02GB too tall. can i replace weight on
    If you remove the top weight then raise the feet to bring the machine up to the worksurface, it won’t be able to tip anyway, so you could just do without it.
    kimba
    Thanks!!!! I will try that.
    k
