These new fangled drain pumps on the WAE /WAS series machines that have a kind of bayonet drain outlet hose fixing. How the hell do you seperate the corrogated hose from the pump without bu&&ering up the pump outlet latches? 😕
BSH-MAN wrote:Use a twisting motion to remove the drain hose out the pump housing, or just change the motor half. 😉
Thanks for that, it’s just that, on a couple of occasions, I’ve needed to remove the filter body completely in order clean and descale it. Doing it in situ not much of an option and all the while risking breaking the latch fixings. I’ll do the twisting motion next time. 😉
