MACHINE spins but does not wash
either the g/box has seized or is there some sort of clutch or maybe a broken cog ?
any body had any dealings with these if so how much of a job is it
Direct drive via the belt and pulley, so prob a gearbox fault. Remove the tub springs and the whole tub and gearbox assy lifts off. When you replace the gearbox you will also need the drive bell and seal kit. Not too bad a job, just needs a bit of thought
I’m going to a Heubsch machine in the morning.
She doesn’t know the model number, but it’s a top loader and it’s big enough to get her quilts in!
It leaks and it doesn’t agitate.
Anyone got any tech info on any of these machines?
How much for a belt, drive bell and seal kit (as mentioned on this thread), etc?
Thanks,
Pigpen
