Hi all.
Having previously found some really useful info on this forum, I’ve now got an error code showing on our DC27 and can’t find the solution on here – so I’m after your advice please!
Having run a complete cycle on the machine, I went to offload it only to find that it was still full of water in the bottom. Also had an error code showing – both the prewash and wash led’s were flashing (leds 1 & 2).
I manually drained the machine (tipped it up) then tried it on a cold rinse cycle – it filled but would not drain.
I’m guessing that the drain pump is u/s… ?
Question is, would this be something that is fairly cheap/easy to repair or should I look at replacing the washer (coming up to 4 yrs old)?
Thanks in advance,
Matt
