Hotpoint BFI680.
Anyone know if a high pressure sensor is normally open and closes on high pressure, or is normally closed and opens on high pressure?
Note, this is not the fill sensor, rather the sensor on the output of the motor, to detect filter clogging. Thanks Keith
well you can work it out from the picture on the shop site
the switch is a standard micro switch. if you look at the picture you can see 3 connection but only 2 have terminals. If you compare it with a micro switch you can see the connections are on the common connector and the normally closed connector
