High-temperature adhesive for glass hob
Home Forums Public Support Forums Help And Support Cooker And Oven Forum High-temperature adhesive for glass hob
  • #27089
    Dabchick
    Our electric cooker has a glass (to use a layman’s term) hob top which is stuck down to the stainless steel body.
    This is now coming unstuck, and I would appreciate advice on what sort of adhesive to stick it down with, and if appropriate what solvent should be used to remove the old adhesive.
    Thank you
    #212558
    Re: High-temperature adhesive for glass hob
    This stuff:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=302
    has temperature rating and will stick anything to everything.
    Cleanliness is essential – a certain amount of the old glue will peel off, some will scrape off amd some will have to be attacked with white spirit (rubber gloves, please). When re-glueing, you will need to weight the two surfaces together for 24 hours to ensure a proper bond.
    Power off before doing anything.
