Hi. My slimline dishwasher refuses to work! The light comes on when the start button is pushed – so I’m going to assume that it’s not an electrical fault – however nothing happens when the dial is turned to the wash settings. Please can someone advise.
Many thanks
Re: Hinari Lifestyle HDW40 – lights are on but nobody’s home
That sounds great – thank you. Can I order a microswitch easily if that is the case, and in terms of investigating, after turning the power off, should I unscrew the door and then I’ll be able to see the door lock?
