Hisense dishwasher draining issue
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hisense dishwasher draining issue
  • #103163
    Adam Charles
    Hi, I have a hisense hs604240buk.
    says e7 fault code.
    During a wash it stops when i think it ahould drain. The base is full of water. This happens on every wash cycle except the rinse which it drains fine?
    Ive taken off the drain pump and tests the ohms: fine. Also nothing blocking it.
    nothing is blocking it from the base all the way out of thr drainage hose.
    Is there a sensor or something it could be? Or is there something else I could try? Thanks.
    #492025
    E7 is a heating fault, the service info only tells you this:
    Heating error. In case of heater fault the machine continues with program.
    But basically, the machine is detecting an error on the heating circuit, somewhere.
