Temperature indicators on the door says 6, -12, -17
(for fridge, fresh and freezer parts respectively).
but
Temperature measured with IR –
Fridge: 7 at the bottom rising to 10 at the top
Fresh: 6
Freezer: 6
What I’ve done so far:
– Tested the freezer thermistors. I forget the actual numbers,but both are in the region of 2kOhms at room temp, dropping rapidly when held in the hand
– Fan in freezer section is working
– Compressor is working
– Evaporation tray above the compressor is dry
– No error codes.
– Completely defrosted and turned off for an hour then back on again
– “radiator” behind the freezer section is free of ice and debris
What I don’t really understand is the disparity between the display and the actual temperature.
Is the controller board to blame?
I’ve seen some posts here saying to reset it, but I can’t work out how to do that.
I don’t _think_ it’s airflow or drain problems…
Any help greatly appreciated as I’ve just lost a freezer full of food.
It was working fine up to a few days ago.
