Hisense hv672c60uk
  • #102752
    mikehha
    any one have any info on these dishwashers just been to this one that is continuously pumping no display and there is no water in the base but because I can`t get it to do anything I dont think the door lock is working any information much appreciated.
    #490332
    did you check timer for blown components ?
    mikehha
    could not see anything obvious on the lower board but did not take the door apart to check the touch panel because it wasn`t showing any signs of life.
    #490334
    well if the pump is running you either have a problem with the float sw or a shorted triac on the board
    mikehha
    yep new board !
