Hisense RB327N4 fridge door seal
Home Forums Public Support Forums Spare Parts Help Hisense RB327N4 fridge door seal
  • #103269
    GoldmanT
    Trying to find a door seal for the fridge part of this fridge freezer – I’ve checked and I’m pretty sure that any RB327N4 is the same size, the letters after it just denote the type of finish and whether the door has a water dispenser etc. (this link should show images of the different types of the same unit: https://www.google.com/search?q=rb327N4+fridge+freezer&oq=rb327N4+fridge+freezer)
    Any help on finding this part would be appreciated – I think I found one that could have been compatible but it was about £50 and I couldn’t be sure it would actually fit when it arrived.
    I don’t mind if it’s a twin-pack with the freezer seal as well, I know they’re different as the doors are different sizes.
    #492417
    For a lot of Hisense parts, in order to find them, the model number is important but increasingly where there are several versions as there is for that model, I really need the info from the barcode label that’s usually at the rating plate, it’s all explained here:
    https://www.ukwhitegoods.co.uk/help/spare-parts/finding-parts/4355-hisense-spare-parts
    GoldmanT
    Ah brilliant thank you, luckily the sticker was on the inside not the back:
    Model: RB327N4WW1
    Batch number: BBJA0 (possibly B8JA0)
    Barcode: 1B0252Z0039JBBJA0P10182
    #492419
    That part number you are after is K1996526 but I can’t locate stock of one anywhere right now.
    GoldmanT
    Thanks for that. That part number brings up this part but doesn’t confirm whether it’s a fridge door seal or freezer door seal. Do you know the part number for the freezer seal?
    https://www.hisensespares.co.uk/spares/fridges-and-freezers/door-seal-magnetic/1102707.htm
    #492421
    The freezer is K1994675.
    GoldmanT
    kwatt wrote:The freezer is K1994675.
    Thanks for your help above – I took a punt on the seal in the hisensespares.co.uk link above and it’s a perfect fit for the fridge door, in case anyone else finds/needs this.
