Hitachi R826BC1 Frost-free F/F
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hitachi R826BC1 Frost-free F/F
Viewing 15 posts - 1 through 15 (of 15 total)
  • #18799
    RickT
    Trying to trace part number for the freezer thermostat. Capillary is mounted inside a plastic tube that sits inside the thermostat box. Maybe nla
    #180459
    Steven
    Re: Hitachi R826BC1 Frost-free F/F
    Could be HTCR621DF115? special order if avialable from connect
    Steven
    #180460
    RickT
    Many thanks Steven. Will give customer the good news
    Cheers Rick
    #180461
    RickT
    Been to customer to confirm thermostat problem but as usual it’s working fine when I get there. Customer says it seems to be sticking in the defrost cycle and by turning the defrost timer on it comes. Could it be the defrost control stat and if so has anyone a part number.
    Thanks Rick
    #180462
    gegsy
    Im not familiar with these so bear with me.
    Is the defrost timer the usual type, if so when it “sticks” is there still a feed to its motor?
    The usual defrost timer motors used to go weak after some usage, and they lost the strength to turn off the defrost cycle.
    Worth a check anyway 😀
    RickT
    Hi Greg
    Timer is the old blue and white Sankyo type TMDE812C. Didn’t get time to check circuits as when I was removing the evaporator cover to check defrost heaters etc the freezer sprang back into life.
    Rick
    #180464
    gegsy
    Sounds like the usual suspect then 😉
    RickT
    Do you have any part numbers available or an equivalant.
    Rick
    #180466
    Dave_Conway
    Masterpart’s UN53133 is described as a “Sankyo type” so that should do the trick 🙂
    #180467
    RickT
    Thanks Dave. Haven’t got account with Masterpart. Can I order as a one off? I mainly trade with Connect and Part Centre to suit my needs.
    Cheers Rick
    #180468
    Dave_Conway
    Type “Sankyo” (without the quotes) in to Connect’s website, there’s a few there.
    Masterpart won’t supply non account holders but I can get it for you if required, about a tenner with post etc.
    #180469
    RickT
    Cheers Dave, let me know the final cost and how to pay and I’ll go with that. Checked on Connect but numbers didn’t match from what I could see. This timer is TMDE812C (8313)
    Rick
    #180470
    Dave_Conway
    Masterpart’s description doesn’t give the type number either to be honest but most timers are quite interchangeable, just check the contact details.
    If you PM me your address etc I’ll get it sorted.
    #180471
    ANDYVIVO
    UN53133 = TMDE625ZF1
    Regards Andy
    #180472
    Dave_Conway
    Cheers Andy, one on order today 🙂
