hitatci w/d mod. fwd135w ser no. 004621
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hitatci w/d mod. fwd135w ser no. 004621
  • #29545
    richardable
    golden oldie w/d.
    called to this one, customer reports w/d trips on progs 5 and 6.
    tried prog 4…ok. water in, motor action, heater, drained, spun.
    tried prog 5..ok for about 10mins then trips out.
    sugested customer trys different progs, she says 5 trips, 6 trips, fast wash trips. but drain and spin ok. i know it sounds like timer, any other ideas as the cust is really fond of w/d and wants it fixed. i said it may be obsolete…is it?
    thanks
    richard
    #223559
    robbra
    Re: hitatci w/d mod. fwd135w ser no. 004621
    just about to send mine to the scrap after 18 years . All electrics ok so if you want some parts let me know.
    Strange fault and could be anything but have you checked motor brushes and meggered the element? Also may be a slight leak.
    Rob
    #223560
    richardable
    rob, thanks for post. i haven’t checked brushes, nor heater, cust is going to try a few progs and let me know, thanks for offer of parts, i’ll post update when i get news.
    thanks
    richard
    #223561
    Weird – was soldering the power board back together on one of these this morning……
    Hadn’t seen one for years!
    richardable
    Re: hitatchi w/d mod. fwd135w ser no. 004621
    chris, thanks ….small world, i know its wierd, as above i’ll post when i get some feedback from cust.
    richard
    #223563
    Gordy29
    try testing heater after it trips i think this is very similar to the old servis quartz .dos not start to heat afterfill .you can use the old type hotpoint heateras long as you fit toc in heater tube.
    #223564
    richardable
    gordy. thanks for tip, when i put it on prog 4 it filled , wash action and the heater came in and the w/d worked as it should!!!!! 😕 .on prog 5, customers favorite prog the machine triped out after about 5mins. 😕 😕
    info from cust will be available soon. will post.
    richard
    #223565
    richardable
    customer rang today..prog 4 fine allthe way through no probs…prog 5 tripped out. suggested as the machine was family friend that if the wash results were satisfactory on prog4 they should run it until it finally dies. would i be right in thinking spares for this golden oldie are like hens teeth?
    richard
    #223566
    Spares……..
    Hotpoint brushes, Hotpoint heater with the sleeve in, “adapt” a Hoover pump to fit, Logic belt, Eaton valves if you need to pop a solenoid valve on, pattern bearings and door gaskets still about, EMW and QER still repair the board – it’s rust and drum pulleys that kill these off.
    robbra
    Richard,
    Trouble is that prog 5 is fast spin and prog 4 is slow so she may have to do a spin but on these it involves a rinse and spin as no spin only prog.
    Rob
    Ps would only use the real Servis element on this as the element on these is resting almost on the plastic tub whereas the hotpoint has the metal plate is under the element and I have seen a melted tub with the hotpoint one. The Servis one has two cut outs on it just for this reason. I have one if you need it.
    #223568
    richardable
    thanks to all for the tips and info 😀
    richard
    #223569
    richardable
    customer rang today…prog 4 still ok..i suggested she tries moving prog to rinse spin to check the motor..she rang back, all ok.. rinses twice and then fast spins ok..no trip out. beginning to look like the heater?
    suggestions please
    richard
