HJA6855 Integrated Fridge Freezer fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries HJA6855 Integrated Fridge Freezer fault
  • #69182
    razor
    Hi all went to this today don’t usually do them but good customer , fridge sitting at 10degrees , in the freezer there was build up of ice fan not running does the fan run constantly? told her to give it a full defrost for 48hours
    any help
    thanks
    #373959
    SAMURI
    Re: HJA6855 Integrated Fridge Freezer fault
    If you open the doors the fan stops you need a magnet to test the fan.
    In the freezer on the right hand side you will see a small cover near the middle baskets.
    With the fridge door closed and the freezer door open put the magnet near the cover to check the fan if the compressor is running the fan sould work.
    If the fan is not working it will be the fan or sensor faulty.
    If the fan is ok and it is icing up it will be the no frost evaporator sensor faulty.
    Bob
    #373960
    razor
    Many thanks , bob for that
    Sent from my HTC One X using Tapatalk 2 Beta-6
    #373961
    razor
    Fan and compressor running ok, would anyone know part number for the evaporator sensor, can’t see it on connect
    #373962
    SAMURI
    Phone. A.W.S. 01603 412324
    Bob
    #373963
    razor
    Hello bob, I see on connect the heater and a sensor , would it be better replacing both , no reading from heater when I checked it with meter
    #373964
    SAMURI
    I have repaired hundreds and never had a heater fail.
    I am sure you will only need the sensor.
    A.W.S. will be cheaper for the part
    I just received your PM
    Bob
    #373965
    razor
    Thanks for help bob
    Raymond
    #373966
    razor
    Would you happen to know part number for sensor
    am l right in thinking its connect 5045173287525
    #373967
    SAMURI
    No that is an incorrect part. Phone AWS as this would be your cheapest option and tell them the model number eg APM6855/0 or APM6855/1 .
    Ask for a no frost evaporator sensor and they will supply you with there part number.
    Bob
    #373968
    razor
    Many thanks bob for all the help
