HJA8362 dishwasher drains then does nothing else
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries HJA8362 dishwasher drains then does nothing else
  • #65752
    Simon46
    Beko Starts off draining then doesnt fill. Filled machine manually with jug t o trip pressure switch to kick in circulation pump still nothing. Does this have flowmeter or is it pcb fault?
    S.
    #361739
    Simon46
    Re: HJA8362 dishwasher drains then does nothing else
    Replaced PCB still the same. It does have a flowmeter. Found 3 TAG microswitch in antiflood polystyrene float is burnt out. Not running drain pump but diconnecting supply to inlet valve. No water in base but a little noticed in tubes to antiflood. What would cause this? Overfoaming? What is part no of flood switch assy?
    S.
    #361740
    Criscold
    Beko 1888100100
    #361741
    Simon46
    OVER FLOW INDICATOR about a fiver. Cheers mate.
    S.
    #361742
    Simon46
    Well fitted this and new module. Still no fill. Spent ages checking everything. No supply to inlet valve. Given up.
