HLV241 Button 4 flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HLV241 Button 4 flashing
  • #86078
    alighthouse
    Hello – just moved into a new place which has a Hotpoint HVL241 washing machine.
    This functioned fine for the first couple of cycles, but now will not operate. When programmed to start, button 4 (“extra rinse”) flashes in addition to the rapid flashing of the door locked button, whilst making a noise as if the pump was trying to engage.
    Cleared out the pump (which had a bunch of coins in it), then button 1 and 2 started flashing.
    After a few minutes, it goes back to only button 4 flashing (along with door locked) and the machine itself is vibrating.
    Any clues please?
    #430247
    Re: HLV241 Button 4 flashing
    Wrong model number, should be HVL241, 😉
    1 & 2 flashing is a communications error, 4 flashing is F01 motor triac short circuit.
    Could just be poor motor plug connections, worn motor brushes or main circuit board failure. 🙁
