Hob Burner Sealing Gasket
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hob Burner Sealing Gasket
  • #100310
    menderman
    Oven CDA. CD9002/1
    I need a new middle burner sealing gasket but can not find any on here – am I looking in the wrong place or is there none here. There is only one fitted and its the big middle one.
    Thanks [h=1][/h]
    #480122
    cant see any but as far as i know your unit is made by Delonghi and rebadged CDA
    either send a message to the shop and ask
    or search delonghi burner gasket or seal and see what popos up
    menderman
    Thanks. Turns out its this https://markselectrical.co.uk/DTR906DF_DeLonghi-90cm-Dual-Fuel-Range-Cooker
    CDA no longer “Make” them. Mine is about 12 years old but that delonghi is exactly the same apart from cosmetic knobs and handles so should be hopful for parts as recently CDA have told me they no longer do the elements for it..
    #480124
    most elements are not a problem as if all else fails we have a firm in liverpool that can make to pattern
