Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Hob flames low when oven lit?
- This topic has 8 replies, 3 voices, and was last updated 7 years, 6 months ago by
DaveAS.
September 23, 2018 at 6:31 pm #94707
DaveAS
ParticipantI have a Swan gas cooker & recently when the oven is lit the hob flames reduce in their intensity. Is this a simple fix or time for a new cooker?
Sorry if this problem has been posted previously.
Thanks in advance.
September 23, 2018 at 6:57 pm #458065kaibart
ModeratorRe: Hob flames low when oven lit?
This isn’t something you can fix yourself you will need A gas safe engineer
September 23, 2018 at 7:19 pm #458066electrofix
does it only happen when you turn the oven on or if you light the grill or turn on more hob burners does it do it then ?
September 24, 2018 at 9:21 pm #458067DaveAS
ParticipantRe: Hob flames low when oven lit?
If the hob rings are the only thing lit, then all is ok. As soon as I light the oven, then the hob flames lower their intensity but go back to full when I turn the oven off. This has just started happening, so I’m at a loss as to what’s going on?
September 24, 2018 at 10:37 pm #458068electrofix
well if it was a gas flow problem to the cooker from the gas main itself I would expect the hob flames to be affected if any other burner was turned on. since it is just the oven and no other combination makes any difference the problem can only be in the cooker
which means you either call in a professional gas safe engineer or scrap it and get a new cooker
September 25, 2018 at 1:57 pm #458069kaibart
The cooker has no regulator and is controlled by the gas meter so it’s a gas safe engineer you need
September 25, 2018 at 6:50 pm #458070DaveAS
Thanks for the reply
Fortunately my brother is a gas safe engineer so I’ll let him have a look.
September 25, 2018 at 7:03 pm #458071kaibart
He will need to check the working pressure if that’s fine there could be a slight blockage in the gas pipe going to cooker let us know how you get off
October 23, 2018 at 2:46 pm #458072DaveAS
ParticipantSorry for the late reply, I’ve been working away.
We have decided that a new cooker is the best outcome for this problem. The Swan cooker was a cheap replacement & it’s done us for 3 years so time for an upgrade.
Thanks for all your replies.
