Hob ignition on continuously
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hob ignition on continuously
  • #21738
    nickd
    Hob ignition on continuously, will only swich off if electicity is off.
    Hob used very rarely . No clogging of ignition collar.
    Thanks Nickd
    #192342
    Re: Hob ignition on continuously
    Very likely the Ignition Button is faulty and you will have to contact a local CORGI registered gas repairer or the manufacturers own agents to fix it for you.
    You didn’t tell us the make or model however that doesn’t matter if you follow the above info. 🙂
