Hobart Dishwasher CHF40
  • #42787
    neilsukwg
    This machine fills rinse tank, stops at normal fill level then stops.
    Rinse tank heater is ok. No supply to rinse tank.
    If wash tank is filled manually, rinse tank heater is activated.
    Any ideas
    #274935
    A1TEC
    Re: Hobart Dishwasher CHF40
    Is the pressure switch o.k for the change over to heat side?
    Is there a boiler tank safety stat?
    I had one similar a few months back, turned out to be a broken wire in the loom.
    If the loom sits on the base of the machine any leaking detergent can eat away at the wiring.
    Cheers
    John.
