holme washing machine
  • #81204
    kasperwelsh
    holme washing machine ..hwm51000h
    washing machine will emptys and fill after empty then beeps but dose not start wash any surggestions
    🙁 or spin after empty 😕
    #415769
    Re: holme washing machine
    Motor brushes worn out?
    #415770
    If you’re lucky someone will have some technical info but it’s a long shot as that’s an Argos exclusive brand if memory serves me and we have no info on it.
    badabing
    Holme is a Asda brand and this one is made by Haier.
    The machine is trying to tell you an error code.
    If the start light is off and the machine buzzes it is advising the door isnt closed properly (within 20 seconds of the start of the program), so it fills for a few seconds then empties and gives the fault.
    If the start light flashes, it will flash a sequence then stop for 4 seconds and then repeat the sequence.
    So
    2 flashes is Drain Error
    3 flashes is Temperature Issue
    4 flashes is heater problem
    5 flashes is not filled to correct level within required time
    Doesnt Do 6 flashes
    7 flashes is Motor Overheat or Motor Protector Failure
    and finally 8 flashes is Overfilling Error
    HTH
    B
