Holme washing machine
  • #90182
    kimv
    Hi I have a Holme washing machine model HWM51000H, it is approximately 4 years old. It was working fine on first wash today, the second wash completed and I heard the bleeps which indicate the door can be opened at end of cycle but the door wouldn’t open. I switched it all off and after a few minutes was able to open the door. when I tried to do the second wash all seemed as normal, the usual starting up noises etc but then suddenly all stopped and 6 bleeps sounded with the stop/pause button also flashing. I am sure its usually 3 bleeps and the button flashes when the wash is finished and the door can be opened, so is 6 bleeps a fault code?
    Any help appreciated, I have a family of four and just before xmas this has me in panic mode.
    #443963
    Re: Holme washing machine
    Unless someone happens to have access to some info on it…
    http://www.ukwhitegoods.co.uk/help/abou … appliances
    Some of the Vestel codes may well apply but, what ones goodness only knows.
    1totalshambles
    Usually it`s motor brushes worn out.
    Word of caution. This machine from memory is the same as a Russel Hobbs ( Chinese re-badged Haier )and if I`m right it is fairly common that one motor brush wears out way faster than t`other so just because one brush carbon is a healthy 4cm long will not mean the other will be too so check both.
    #443965
    4 years is a good lifetime and I expect Kim has gone back to Argos for another one! 😉
    #443966
    1totalshambles
    Martin`s Xmas wit!
    If it is the motor brushes and a Haier motor change the black plastic motor brushes for Indesit brick red holder type part number C00273898 ( but it is up to you via a picture to double check ) as these are harder carbons but run them in 1st over 2 to 4 washes minimum with small/light loads first and these will last longer in the long run.
    Holme, Haus, Haier and some Chinese Amica machines are not that bad a machine in the lower spin and capacity sizes but not as easy to work on compared with Vestel Turkish stuff but there`s not a lot in it really except bearing changes..
    Some of these cheaper brands, overall, can be very successful: 1000spin Haus £<£180, 7 years old gone wrong once-filter blockage and is still going ok. Neff circ 800 quid, drum bearings failed at 3-4 years old £460 on parts alone to put right equals 8 boxes of Kleenex tissues worth in tears alone!
    Happy New Year Martin.
    #443967
    1totalshambles wrote:Martin`s Xmas Wit!
    Err maybe, but more a reality check. Kim’s probably spotted the “go Argos” ad over Christmas flogging 1600rpm Beko’s for £179 I shouldn’t wonder. 😀
    1totalshambles wrote:Happy New Year Martin.
    and to you dear boy!
    #443968
    1totalshambles
    Martin, old fruit, old thing.
    Nope, he saw the Argos Bush XMas day special 8kg 1400 spin at a groovy £150 and thought, hmm, instead do I buy a mid range Bosch with potential drum bearing/spider arm failure at 4 years old at 400 odd quid or do I get to own and play about with my Chinese Bush ( now keep it clean please! ) get 3 years out of it maybe even 7 years and go away laughing all the way to The Leeds either way.
    Dilemmas, dilemmas.
