Homark 0-700401/1 oven Minute minder
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Homark 0-700401/1 oven Minute minder
  • #88262
    Twoten
    Does anyone have a part number for the minute minder/timer for the above single oven.
    The serial number if required is 0 04 10003 – 0916HM111
    Thanks,
    Keith.
    #437510
    hyg-dip
    Re: Homark 0-700401/1 oven Minute minder
    76×4837 Part is no longer available
    #437511
    Twoten
    I wondered if that would be the case.
    Thanks for looking it up Hyg-dip.
    #437512
    aqualectric
    Is this a 2hr analogue timer? Put “analogue oven timer” into Connections and there is quite a few to choose from. Also Connect 5031680256321 Delonghi timer may fit the bill. Maybe a little adaption required but that’s what we’re good at in this trade!
    HTH,
    Steve.
    #437513
    Twoten
    Thanks Steve,
    I just realised I mistyped the model, it should be 02-700401/1
    aqualectric wrote:Is this a 2hr analogue timer? Put “analogue oven timer” into Connections
    The problem is although it’s listed as a minute minder it has a set of contacts that turn the oven off after a set time.
    Unfortunately the timers that come up on the search either don’t give a timed value, don’t have contacts or in many of the cases are no longer available.
    I think the one I am looking for is 5045172202864 but again, no longer available and no alternative shown.
    Keith..
    #437514
    Does the customer actually use the time for timing ?
    If not then by pass the minute minder
    Bryan
    #437515
    Twoten
    It doesn’t need to be bypassed but just set on manual.
    The problem is it’s a tenant that have told the agent they use it.
    Keith.
    #437516
    So you need a minute minder for a oven with the contacts on the back ? I should have one sitting about.May not be the genuine part but it’ll do the job.
    Bryan
