Re: Homark 02-700401 Type B11 Oven Instruction Manual
Whan you say manual, I assume you mean the service manual as opposed to the user manual ?
The user manual won’t tell you how to change the element, I doubt the service manual will either to be honest.
You will need to remove the rear cover inside, at the back of the oven cavity to access the element. You may also have to remove the oven from it’s housing, remove the rear cover to access the screws that hold it in position, it’s not too clear from the diagram.
Whatever you do, disconnect it from the power 1st !!
