Homark 700401 oven not heating up
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Homark 700401 oven not heating up
  • #9128
    My Mum in law has the above cooker but the oven is not heating up. The grill works and the fan is running. Do you have any idea what the fault could be and if so how do i test these items with a meter and where are they situated on the appliance.
    Many thanks
    #132545
    tonyclifton
    Blocked
    Re: Homark 700401 oven not heating up
    it be main oven element,which is located behind a panel at the back of the oven from the inside normally held in place by 4 screws,look for burnt marks on element ,then carefully remove not to lose wires down back and check with meter.
    check out shop@ for one… over on left.
    remember to turn POWER OFF 1st
    #132546
    tonyclifton wrote:it be main oven element,which is located behind a panel at the back of the oven from the inside normally held in place by 4 screws,look for burnt marks on element ,then carefully remove not to lose wires down back and check with meter.
    I can get to the back of the cooker easy enough if that would make life easier. Have you any idea which element it is. What do i expect across meter.
    #132547
    Dave_Conway
    You need to remove the back panel at the rear of the oven cavity first as tony said Blademan, it’s behind it.
    Model number also please to identify the correct element for you.
