Homark 800270
  • #24987
    Petey
    I have a Homark 800270 and it will not advance through the wash cycles as the heater is not working. I have established that there is no power getting to the heating element. Any advice on what to check next would be greatly appreciated. Thanks,
    Pete.
    #204075
    Re: Homark 800270
    Safety thermostat tripped, broken wiring in door, timer not switching are all possibilities. First two can be checked with your multimeter. If OK, has to be timer.
    Can you post up the rest of the model number please? There are four different versions of this Servis built machine.
    Stay safe, power off.
    Petey
    Re: Homark 800270
    Model is 02-800270 S/No 982206946
    The safety thermostat is okay, will check the wiring next. Thanks for the prompt reply.
    Rgards,
    Pete.
