Homark Built in Oven Heating Element
Home Forums Public Support Forums Spare Parts Help Homark Built in Oven Heating Element
  • #9793
    jah21
    We have a Homark 703205 built in oven and need a new oven heating element as ours is not working.
    If anyone could point me in the right direction that would be great.
    John
    πŸ™‚
    Based in Maidstone if that is useful!
    Also hope i have given enough info, if not let me know, cheers.
    #135864
    Email to spares@ukwhitegoods.co.uk will sort that out for for you. πŸ˜‰
    Dave_Conway
    Re: Homark Built in Oven Heating Element
    If you go to shop@ and follow cooker spares then oven and grill elements, it’s ELE2040 in there.
    Sorry, I can’t paste anything at the moment otherwise I’d put the direct link here for you. Reboot required I think πŸ™„
    #135866
    jah21
    thank you both for your advice. Have ordered/received the part and have fitted it and now the oven is working perfectly
    thanks again
    john
    πŸ˜€
    #135867
    Hi. I also have a Homark oven, model number 703205. Could you please describe how to change the heating element. I’ve had a look inside the oven and there are no obvious fixings attaching the rear plate. Thanks!
    #135868
    litlor
    It’s fixed at the back with 2, 7mm nuts power off though when investigating
    #135869
    Thanks for the prompt reply! And presumably it’s a fairly straighforward, intuitive task to replace the element?
    #135870
    litlor
    Its easy when you have been doing this job for the last 30 odd years
    yes easy job but remember to turn off that cooker switch before starting
    John
