Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Homark cooker instructions
- This topic has 20 replies, 8 voices, and was last updated 20 years, 6 months ago by
Ob1kenobe.
October 2, 2005 at 12:44 pm #12312
Ob1kenobe
ParticipantHello can anyone let me know where I can get online instructions to use my new Homark oven!!
October 2, 2005 at 3:45 pm #149032Dave_Conway
ParticipantRe: Homark cooker instructions
Which model is it Ob1kenobe ?
I may have a pdf file here of it 🙂
October 2, 2005 at 4:24 pm #149033Ob1kenobe
omg.. I don’t know.. where would I find that? It is silver colour and it has 6 buttons on the left..lst one a bell, then a pan with ‘flames’, then stop, then a ‘hand’ then a + and -. that is the bit confusing me! sorry to sound so stupid but this is the most ‘modern’ cooker I have ever owned! my old one was very basic ie.. on and off and that was it
October 2, 2005 at 4:34 pm #149034Dave_Conway
It should be around the door somewhere on the rating plate, normally either prefixed by 01 or 02 etc and then five numbers.
It may also be on your reciept.
October 2, 2005 at 4:51 pm #149035Ob1kenobe
right..found it, Mod 05-703205. Type 812. SNr 0816HMGCI-991513. 230-240 v~~50 hz
October 2, 2005 at 8:22 pm #149036Dave_Conway
On the way, not exactly the same model but it’s the closest I can find, hopefully it should help 🙂
October 3, 2005 at 3:40 pm #149037Ob1kenobe
😀 Thank you very much..most helphful
October 8, 2005 at 3:07 pm #149038Cogito
Would you happen to have a PDF for the Homark 02-600101?
Thanks.October 8, 2005 at 9:18 pm #149039Dave_Conway
Cogito wrote:Would you happen to have a PDF for the Homark 02-600101?
Not specifically that model no, but if you can describe it’s basic functions I’m sure I’ll fine one pretty close 🙂
October 8, 2005 at 9:45 pm #149040Cogito
It’s a fan oven with a 2100w element and a separate grill. It has three dials on the front – the first is a timer, the second is the temperature control and the third is the function dial with 4 options: off, grill, oven or light on.
That’s about it.
October 8, 2005 at 10:27 pm #149041Dave_Conway
One on the way then, ignore the timer bit if yours doesn’t have one 🙂
Don’t worry about thanking me 😉
October 16, 2005 at 10:40 am #149042sigh_man
Dave_Conway wrote:On the way, not exactly the same model but it’s the closest I can find, hopefully it should help 🙂
Dave – could you possibly send me the same PDF, as mine has exactly the same controls as the above. Model is 13-801201 but I don’t think that’ll make much difference.
Many thanks
Simon
October 16, 2005 at 1:23 pm #149043Dave_Conway
On the way later (email issues at the moment), I’m sending two so that should cover it 🙂
October 18, 2005 at 6:03 pm #149044Ob1kenobe
😕 now I have my instructions I have been able to cook fine but…when I turn my oven off at the end of cooking the fan stays on. At first I thought it was to cool the oven but at the mo I am having to switch it off at the mains for the oven to turn off completely. Is this a bit fault? and what do I need to do to correct it? many thanks
October 18, 2005 at 6:25 pm #149045NWAR
ModeratorRe: Homark cooker instructions
How long is this fan running for after you finish cooking?
The cooling fan will continue to operate after cooking has finished for anything up to 1/2 an hour or more depending on temperaature reached & conditions (such as air flow around the oven).
Craig
