We’ve got a fairly old Homark double oven. The top oven and grill is working fine but the bottom one seems to have died – no light, no heat no anything. Is it likely to be a thermocouple fault please? If so what is likely cost and ease of relacement (for reasonably adept home DIYer). Thanks.
Try the clock to see if it on auto. Easiest way to do this is to turn on the main oven, set the clock to the correct time of day, then turn the auto knob / alter the buttons to synchronize the times. If it is the clock, the oven should burst into life. The clock only controls the main oven and not the top oven / grill. 😉
I was just about to say “I’ve already tried that”, but I’ve just done what you said and it worked. I can’t believe I’ve been so thick 😳 . We have always had the timer switched off and never used it. I followed the questions in the FAQs with no joy. What a bloody numpty!! Thanks Steve.
