Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Homark Fan Element…
- This topic has 13 replies, 5 voices, and was last updated 21 years, 7 months ago by
Cleat.
August 16, 2004 at 4:00 pm #6041
Cleat
ParticipantCan anyone tell me where the best place to get a fan element to fit the following…… HOMARK model 01700206A serial 5860065000-810187…. Many Thanks..
August 16, 2004 at 4:26 pm #115259Dave_Conway
ParticipantRe: Homark Fan Element…
It’s a Brandt made oven. Element part number 76X3719, about £20 trade from Brandt or MFI.
Ifd you haven’t a contact for either of those, I can order for you if required.
August 17, 2004 at 2:06 pm #115260Martin
Now I am stuck with a Homark oven element problem 🙁 . My customer has a Homark 01801101 built-in oven 🙁
What I would like to know is what ‘equivalent’ element should I be looking for from our ‘pattern boys’ 😉 I reckon it must be the same as an Ariston, Candy, Belling or whatever ❓
August 17, 2004 at 3:07 pm #115261Dave_Conway
Martin wrote:Now I am stuck with a Homark oven element problem
Guess what Martin, it’s the same one as Cleat was after. Without seeing it I don’t know which alternative would fit, Connect show no alternative, neither do Washvac.
The same offfer applied, if you want the gen one ordered, let me know.
August 17, 2004 at 3:49 pm #115262Martin
Dave_Conway wrote:The same offfer applied, if you want the gen one ordered, let me know.
Your a star Dave thanks!
The ‘genuine’ in this case then is £40 odd as listed via Connect 🙁
B**ger that!
What I will do is whip out the duff element, size it up and get a £10 pattern one…The only prob is that will involve 2 calls by hey, ‘que cera amigo!…….Gracias!
MartinAugust 17, 2004 at 4:03 pm #115263Dave_Conway
Martin wrote:The ‘genuine’ in this case then is £40 odd as listed via Connect
Where did you get that price from ?
They don’t even list it as far as I can tell.
August 17, 2004 at 4:39 pm #115264Martin
Dave_Conway wrote:Where did you get that price from ?
I just typed in 76X3719 and Connect quoted £46.54 for an Ocean/Brandt Oven Element (Not in stock, special order …6 weeks wait no doubt?)
I then thought. “???***!!!???***”
….I now use my initiative and serve my customer well with a ‘genuine pattern part’…thanks again Dave 😆
August 17, 2004 at 9:49 pm #115265Cleat
Martin.. i tried typing 76X3719 in Connections and got no result ??? strange… And Dave thanks i tried to order from Brandt as i thought i had a account but found they had closed it due to underactivity… they referred me to A-Z spares.. will try them tommorrow, will let u know the outcome… By the way is it not the same as connects ELE8836 ?( £5.38) as i cant tell as my engineer didnt remove the element ….
August 17, 2004 at 9:57 pm #115266kwatt
KeymasterEhm guys, 76X3719 can be replaced with a Candy element or the Zanussi or Ariston I can’t remember which but when in a pinch. 😉
Doing ovens you should really carry one of each as they will fit loads of machines.
August 17, 2004 at 9:57 pm #115267Dave_Conway
Yeah, I was a bit intrigued by how Martin found that as well, it turns out, it’s only listed on their web based version of Connections at http://www.connect-distribution.co.uk which I find odd as the “local” version running regular updates should be exactly the same product info.
The other one, ELE8836, dunno, if it does fit let us know eh ?
August 18, 2004 at 11:04 am #115268Martin
Dave_Conway wrote:The other one, ELE8836, dunno, if it does fit let us know eh ?
Yes Dave, it was an ELE8836 type I fitted in the end(actually I fitted the Qualtex equivalent = ELE2300 Homark 2000watt)… job done thanks for your help 🙂
August 18, 2004 at 1:11 pm #115269Dave_Conway
Martin wrote:Yes Dave, it was an ELE8836 type I fitted in the end(actually I fitted the Qualtex equivalent = ELE2300 Homark 2000watt
It’s an Ariston with threaded holes 😀
2 ordered for stock 😉
August 18, 2004 at 10:33 pm #115270sparkey
76X3719 element has larger holes so replacement is posible from front without moving oven from housing, You will have to drill out your threads to allow self tappers to pass through plate Dave.
Regards
SparkeyAugust 26, 2004 at 12:45 pm #115271Cleat
Update job complete now ( Customer been on holiday ) ELE8836 was a country mile away from fitting.. engineer fitted Connects ELE3355 (philips i think) after cutting down the top bracket to fit.. Job Done … 😀
