homark fan oven element
Home Forums Public Support Forums Help And Support Cooker And Oven Forum homark fan oven element
Viewing 15 posts - 1 through 15 (of 26 total)
  • #7222
    mrcrow
    my homark built in fan oven model 02 700301 fan element burnt out on christmas eve..:(
    i took off the interior casing over the fan and got the part no. 20 40112 and sized it up …two windings 190mm dia 2000w etc..
    i see two little mounting screws with star shaped heads to remove the element…first i will need to get a tool to fit these…??
    if i get them slackened off can i replace the element simply by taking the old one out via the oven interior and reconnecting the power leads or do i need to take the whole casing out of the fitment carcase..?
    i also note the grill element is fixed via a similar flange but the fixing screws seem to be from behind the back of the oven…
    grateful for any assistance..
    and merry christmas forumites
    yours
    mrcrow
    #122118
    Re: homark fan oven element
    Morning
    PLUG/POWER OFF is the first rule…
    yes, if you remove these screws the element will extract from the front. The wiring is usually long enough to follow the element for an inch or so. If you pull a wire off its an oven out job to recover from the back.
    Hope that helps.
    Kevin
    #122119
    mrcrow
    kheath wrote:MorningPLUG/POWER OFF is the first rule…
    Hope that helps.
    Kevin
    thanks a lot kevin…glad i dont need to take out the oven…
    i will be careful with the cables…may attach some restraint to them prior to disconnecting…string or something to rescue them if they jump back…
    cheers
    geof
    ps that top grill element…with the screws showing coming through from the opposite side..ie not the heads…is that a pull out job?…i could do this one as well as it may go by sod’s law..?
    cheers
    #122120
    Dave_Conway
    Nope, that one is secured from behind, ie, the screws enter the element mounting plate from the rear, which is an oven out job.
    If it’s working, best left alone until it fails really 😉
    If you post up the model number of the oven, I should be able to help with part numbers/prices etc for the fan element, not until Wednsesday now though.
    #122121
    mrcrow
    thanks dave
    homark model no 02 700301
    part no…i looked on the flange…99A 200W E60 20 40112..:)
    the double coil is around 190mm dia and the flange bolt centres about 58mm with the element centre at 26mm…can check these if they seem wrong..
    do i need to buy a special 6 pointed star screwdriver to get the screws out or is there a ‘tip’ on modifying an ordinary or phillips screwdriver to do this job
    finally since you mentioned oven out…are the 4 screws which go through the side cheeks into the carcase all that holds it in…i may need to know this for future..thanks
    i have googled and emailed a bit for spares but havent got replies yet..your offer will be welcomed…
    cheers
    geof
    manchester
    #122122
    Dave_Conway
    mrcrow wrote:homark model no 02 700301
    That’s enough to identify thanks 😉
    mrcrow wrote:do i need to buy a special 6 pointed star screwdriver to get the screws out or is there a ‘tip’ on modifying an ordinary or phillips screwdriver to do this job
    It’s called a torx 😀
    mrcrow wrote:finally since you mentioned oven out…are the 4 screws which go through the side cheeks into the carcase all that holds it in
    Normally yes.
    Im surethe tool you will need is a torx/T20 size, should have no problem gettin one from the likes of Halfords 🙂
    Normally yes.
    mrcrow
    gegsy
    gegsy…cheers man.. i dont do the car anymore as its under warranty..so i havent kept my tooling up to date
    torx it is..!!
    cheers
    #122125
    mrcrow
    Normally yes.
    thanks again..the show goes on…!!
    cheers 🙄
    #122126
    Dave_Conway
    It just so happens we have the element here in the UKW shop.
    If you follow this link:
    http://shop.ukwhitegoods.co.uk/2040-coo … an-element
    #122127
    mrcrow
    Dave_Conway wrote:It just so happens we have the element here in the UKW shop.
    cheers dave..just placed the order…great service
    the pic was huge…but seems like the one
    best wishes…
    geof
    manchester
    #122128
    Dave_Conway
    Got it thanks, it will go today for you.
    The picture is a little on the large size isn’t it :eeek: 😆
    I’ll resize it 😉
    #122129
    mrcrow
    cheers…found a good site for tools which do the torx bits at 0.94p each including first class delivery…ordered the TX15 and TX20 to be sure…
    i see they are in exeter and my old neighbourhood…bridgwater somerset
    http://www.toolstation.com/index.html?code=91568
    😛 ..they do free fone, free fax, and free post…
    now all i need is that part and the tools and figure out which fuse the oven is on.. 😯
    cheers
    #122130
    Dave_Conway
    mrcrow wrote:i see they are in exeter and my old neighbourhood…bridgwater somerset
    I never even knew they were there, I’ll take a look in next time I’m passing.
    Cheers for the link 😀
    #122131
    mrcrow
    Dave_Conway wrote:I never even knew they were there, I’ll take a look in next time I’m passing.
    cheers to you too
    the element arrived first post…whacko…!! 😆
