Home › Forums › Public Support Forums › Spare Parts Help › Homark inner door seal – help required
- This topic has 3 replies, 2 voices, and was last updated 19 years, 3 months ago by
sammington.
January 11, 2007 at 12:18 pm #24041
sammington
ParticipantCany anyone please help me. I’ve inherited (with the house) a white Homark oven. Unfortuantely, the numbers on the ID plate have worn and I can’t read them properly.
I need to the replace the inner door rubber seal which has perished but am unable to find a part number.
The only info I can glean from the ID plate is:
Type: 02- then I think its a 6 and ends in 0
Next box down I think is Series and the only digits I can make out end in 00524.The only other info I have is the the inner glass itself has a number of 031346.
The oven is white, on the LHS is the timer knob, and on the RHS Grill knob and then to the right of that the Fan Oven knob.
Any help would be very much appreciated.
January 11, 2007 at 12:43 pm #200323Dave_Conway
ParticipantRe: Homark inner door seal – help required
sammington wrote:Type: 02- then I think its a 6 and ends in 0
That’s the important bit if there is any way you can try and make it out.
There are so many Homark variations made by several manufacturers, without the complete model number it’s nigh on imposssible to identify the parts I’m afraid.
It may also be worth checking with neighbours as quite often housing estates are built and all have the same appliances installed 🙂
January 12, 2007 at 3:51 pm #200324sammington
Hi Dave, thanks for your quick reply.
Unfortunately, there is no way the rest of the numbers can be read. I’ve take the plate off the oven and tried the old wax crayon thing but its absolutely flat.
Brill idea about the other houses too, but unfortunately, its not the original oven. I’ve even tried to get hold of the people who installed but to no avail.
I’m getting to the point where I’ll just go for anything and if necessary cut it down – its got to be better than what I’ve got a the moment which is just three corners! 🙁
January 12, 2007 at 4:04 pm #200325Dave_Conway
It will have either been manufactured by Nardi or Brandt, can you email me a photo of the oven with the door open to spares@ukwhitegoods.co.uk and I’ll see if I an narrow it down 🙂
