I’ve moved into a flat with the cooker mentioned in the subject line. The bulb seems to have gone. I’m afraid I don’t know how to get the bulb out, never mind what type it is. Can anyone help?
Wonderful, thank you. The cover came off with a bit of persuasion.
The cooker was left in a real state by the last owner, I had do some serious cleaning. The lamp cover was really stiff as it was clogged up with grease and I didn’t want to try to turn it really hard until I knew that it was meant to come off that way!
Would the 25W bulb and the 15W bulb both be appropriate replacements?
Yup, you can get them in Shop@, but TBH most DIY places have them these days, or any local repair shop.
If the oven is a real burnt-on greasy mess BTW, make up a strong solution of biological washing powder in WARM (not hot) water and drop in all the bits you want to clean – leave overnight and in the morning the greasy mess will quite literally wipe off!
