Homark Oven
  • #40809
    Mel85
    Please can someone send me a manual or instructions for our oven We have just moved into a new flat and we cant figure out what the symbols on the dials mean!
    The model number is: Homark 02-700301 type B
    It has a timer dial on the left hand side and another dial on the right hand side that has the following symbols:
    1. a fan with 2 triangles above
    2. a fan with 3 filled in triangles above it
    3. A fan with a circle round it
    4. A bulb
    It seems that all the triangle features activate the grill and no certain one for the oven setting…bit confused.
    Mel
    #267628
    don
    Re: Homark Oven
    Hi Mel
    Fan with two triangles will be half width grill and fan, otherwise called hot air grilling.
    Fan with three is full width grill and fan.
    Hot air grilling as it`s known, is where the grill and fan operate alternately with the grill producing the heat and the fan distributing the heat. Result is evenly cooked and crisp food.
    The fan with the cirlcle around it will be the normal cooking fan mode.
    HTH
    Don
    Affresh washing machine cleaner
    #267629
    Mel85
    Re: Homark Oven
    Thanks that explains a lot.
    The grill works fine but seeing as the light doesnt come on and the oven setting only blows the fan and brings no heat should I assume the oven setting needs to be fixed. If so any idea what the problem may be?
    mel
    #267630
    Re: Homark Oven
    Most probably the fan element that’s gone on it Mel.
    The element is a common one, available here
    HTH
    don
    Re: Homark Oven
    Hi mel
    Sounds like the fan oven element needs replacing. Click the Find An Engineer in your post for assistance or if you are going to attempt a DIY repair ensure you unplug from the mains first.
    Don
    #267632
    Mel85
    Re: Homark Oven
    Thank you so much for your very speedy replies!! Very impressive! I shall ring the landlady and get her to organise someone to come over to fix it. If I have any more problems Ill be sure to come to you again!
    Mel
