homark oven controls
  • #6007
    mrcrow
    i have moved into a ‘new’ house which has a
    homark oven and hob
    the dials on the oven are
    lhs…timer and manual dial
    rhs..temperature and
    function
    the function dial is divided int 5 settings
    off
    lamp only
    fan only
    fan with 3 triangles..
    fan with 2 triangles
    the oven has a grill rail and grill pan with handle
    but when grilling the fan is on…as per the two settings
    can anyone help please and tell me if there should be a grill only setting and where it might be?
    i have looked at some more modern built in ovens in b and q and their controls are a bit self evident as to what to use for grill only
    much obliged for any advise
    ps…i reckon the oven could be from around 1992 since that i when the kitchen was modernised..
    yours
    mrcrow
    irlam
    manchester
    #115076
    Dave_Conway
    Re: homark oven controls
    If that’s the only grill symbols there are, it can only be set to either full grill or half grill, both with the fan running. This older model probably didn’t have a cavity cooling fan, so the oven fan will be acting as some form of air distribution to stop the cavity overheating I expect.
    #115077
    mrcrow
    thanks dave
    this is what i suspected
    there is no cavity for a grill chamber as such…the oven is the cavity so what you say seems to make sense that a fan should be running when grilling…
    the exposed element for the grill in the roof of the oven does the grilling and as far as i can see heats the oven as well.
    i was googling for the homark site to see if i could get some more info but didnt get too far..just came up with spares suppliers.
    thanks again for the reply
    mrcrow
    irlam
    manchester
    #115078
    hi
    i moved into house with homark oven too, but settings on the controls have faded. so it’s been a matter of guess work, trial & error! i can’t seem to get the grill to work tho. maybe the element has gone?
    there is a diamond shape, a ‘v’ shape, then F & 2 more settings after that. i gathered the F is fan oven – i’ve managed frozen chips on that setting. but i’m not sure on the rest! any clues?
    bubbleflowery@hotmail.com
    #115079
    Dave_Conway
    Karen, if you do a forum search for Homark I posted a picture of the control panel some time back, it should help.
    #115080
    miss
    I have just moved into a house and have a homark oven. is there anywhere i can find out what the symbols mean. I cant find a model number either all I can tell you is its green (typical female). I did do a forum search but cant find any pictures. Please please help.
    #115081
    Dave_Conway
    miss wrote:I did do a forum search but cant find any pictures. Please please help.
    The post is here miss 😀
    viewtopic.php?f=5&t=2915
    #115082
    miss
    Thank you very much.
